VSS questions
Old Dec 23, 2002 | 03:30 PM
  #16
jimlab's Avatar
After contacting Dakota Digital (again), they mentioned that they now have a device called the SGI-5A which can multiply/divide by a factor of 4.
Since I need a conversion factor of approximately 5.67, I've asked if I can use an SGI-5A with an SGI-5 in series to divide the output of the VSS (45,331 ppm) by 4 (~11,333 ppm) and then again by 1.414 (~8,012 ppm).
A slightly more complicated solution than I wanted, but less complicated than trying to set up a GM PCM solely for speedometer conversion use, less expensive, and the solution will consume less space also.
I might be able to finally put this one to rest.
Old Dec 24, 2002 | 09:39 PM
  #17
oemfisystems's Avatar
17 for the t56-if you email me the #'s, I can send you back all the constants.
jim
dluna333
15
Mar 13, 2015 12:30 PM
jasonduaine
Mar 7, 2015 09:44 AM
30thZ4C
Wheels and Tires
Jan 29, 2015 06:03 PM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
Hurin
Dec 13, 2014 07:38 PM
