VE tables in SD DA2 question.
Old Jul 2, 2007 | 10:27 PM
RACEON's Avatar
I have two tunes that work pretty well in my 93, and I was looking at the tunes and the only real difference is within the VE tables. If you have higher numbers in the VE table does that mean you added fuel or it was taking it out?
The reason I ask is after the VE table with higher numbers was put in the car runs leaner, as noted by plugs, but my idle is harder to maintain till warm as it takes allot of throttle play with my foot to keep it running till it is able to run on its own. The tune with the lower number VE tables starts fairly well and doesnt take long to hold its own idle in park and in gear.
Just learning here guys, trying to figure out some idleing issues, and this is the only thing different on both tunes, and I cant figure out why the idle performance changes so much.
DirtyDaveW
Dec 1, 2016 05:37 PM
Bigtoyz97
Sep 21, 2015 01:44 PM
Latronaxe
Jul 20, 2015 12:00 PM
MichiganSkip
Jun 8, 2015 10:30 AM
GetaZforgetGT
Aug 14, 2002 07:35 AM
