TunerCAT tables for Burst Knock????
Old Aug 13, 2002 | 03:17 PM
GetaZforgetGT's Avatar
Post TunerCAT tables for Burst Knock????
I see that there is one for Burst vs. Coolant temp...Is this the only one.
I believe Burst knock is causing me some headaches.
My problem is that I don't see knock unless I smash the throttle wide open. If I slowly increase the amount of throttle I don't see any knock. As a side note, I still have the stock T-stat and the table show 3-5 degrees of retard in the 170-180 deg. range.
Which brings me to a new question. What is the easiest way to set my Knock Recovery rate to a safe level.
Jeff
95 Z28
A couple mods, nothing worth mentioning though
Old Aug 13, 2002 | 03:26 PM
Hal Fisher's Avatar
Post
Does it knock if you gun it in neutral?
Hal
[This message has been edited by Hal Fisher (edited August 13, 2002).]
Old Aug 13, 2002 | 03:31 PM
Post
Yeah but the knock isn't as bad.
Jeff
95 Z28
Old Aug 13, 2002 | 05:47 PM
Hal Fisher's Avatar
Post
More info is always better. What are the actual retard numbers? Maybe send me a file of you reving it in neutral.
I can send you the calculator for the desensitizing circuit if you want it.
Hal
Old Aug 14, 2002 | 07:35 AM
Post
I'm reading it off of a scanmaster so I can't really send you any files at the moment. I have freescan but no laptop for the runs.
I really don't think its a knock sensor problem. I know a lot of people were tuning out burst knock and having good results so I was looking for info on that.
Jeff
95 Z28
IndyZman
Oct 22, 2015 02:17 PM
SergheiS
Sep 29, 2015 08:56 PM
SEOJustin
Sep 24, 2015 04:39 PM
MDZ28
11
Sep 24, 2015 09:15 AM
Bigtoyz97
Sep 21, 2015 01:44 PM
