Vats disable question?
Old Feb 18, 2010 | 10:18 PM
ishz28's Avatar
Before I have my ECU reprogrammed I have a question about the VATS disable offered by them. I have a resistor soldered in there now to override it, if I disable it will the resistor have to come out or can I leave it alone? Thanks.
Old Feb 19, 2010 | 12:12 AM
meangreenchevy's Avatar
shouldnt make a difference in my opinion. if the ecu isnt looking for the resistance then the resister being there or not shouldnt matter
Old Feb 19, 2010 | 07:52 AM
ishz28's Avatar
Thank you, I know it's probably a no-brainer question, but my OCD has to be appeased sometimes.
Old Feb 19, 2010 | 09:54 AM
bobdec's Avatar
+1 on meangreen's answer (post #2) ... don't forget the resistor is allowing the Theft Deterrent Module (aka: VATS) do two things 1- signal the PCM (allows injectors to pick) and 2- picking the Theft Deterrent Relay (TDR) that allows the starter solenoid to pick. If you pull the resister the security lite will come on, injectors will still work due to programming out PCM VATS, BUT the starter will not pick unless you bypass the TDR. So keep the resistor in...
Klypto
Mar 9, 2015 04:25 PM
Noer
Feb 28, 2015 11:29 AM
Lakebratt
Feb 5, 2015 07:55 PM
cmdeshon
Dec 27, 2014 10:06 AM
Fedesna
Nov 23, 2014 11:06 AM
