V6 PCM Problem?
Old May 2, 2004 | 05:57 PM
Live for TAs's Avatar
V6 PCM Problem?
My 1997 OBD2 V6 Firebird has some problems-
The speedo stopped working, then the fans stopped working, then the SES light came on for a while and now it is out. When I plug in a scanner to the OBD2 service port, I get no reading or power. I checked all fuses & they are OK.
The car starts & runs fine, but is overheating at idle due to the fans.
Could the PCM be going bad?
Old May 4, 2004 | 07:33 PM
1 down & 1 to go!
As it turns out, the cigar/acc fuse on the 1997 model apparently also powers the OBD2 diagnostics. This fuse was blown, I replaced it & now the fans & scanner work but no speedo/odometer.
Time to test the vehicle speed sensor from the look of things.
Old May 6, 2004 | 06:11 AM
Problem #2 solved. It turns out some <Red Forman> dumb***</Red Forman> had cut off the plug to the speed sensor and soldered the wires to the pins . Fortunately, I had an old LT1 harness & cut off the speed sensor plug and wired it up like it should be.
DirtyDaveW
Dec 1, 2016 05:37 PM
Scottyboy
Feb 11, 2015 10:28 PM
AlaskaZ28
Jan 1, 2015 12:30 PM
97SSdude
Dec 31, 2014 07:43 PM
JSK333
Sep 9, 2002 10:33 PM
