using a 96 PCM in a 95?
Old Sep 21, 2002 | 08:20 PM
Red_94Formula's Avatar
will this work? what needs to be done?
thanks
Old Sep 21, 2002 | 10:11 PM
Dave 96TA's Avatar
I dont believe its a plug-and-play swap, if possible at all. The OBDII PCM reads a couple sensors that the OBDI doesnt even have, so you'll run into problems right there. You'll also have to install a 96+ knock sensor. I think your other problems will be rear O2 sensors, EGR, AIR, , crank position sensor (some can be taken care of with [expensive] programming). The OBDII PCM is much more picky and often wont let you get by with much more than low windshield wiper fluid.
Old Sep 21, 2002 | 10:46 PM
Thomash's Avatar
You will need a OBDI computer I think a 94 will work. 97 will not.
Old Sep 22, 2002 | 08:47 AM
Red_94Formula
we lost power when flashing the 95 PCM so it fried that one. i heard the dealer can re flash it. does anyone know how much that costs?
thanks
Old Sep 24, 2002 | 04:14 PM
kevin97z28's Avatar
No, The 96 will not work with a 95. Not only is it not OBD compatible, the hardware inside the PCM is different. The flash that holds the code are different sizes, even though it may be possible to convert the PCM if you werent worried about emissions, and diagnostics. Kevin
Old Sep 25, 2002 | 09:41 PM
jgeorger's Avatar
Re: using a 96 PCM in a 95?
thanks
I think a few people on the LT1-Edit list have done it, because it solved some shifting problems high power A4's were having. The knock sensors are different, and the 96's added rear O2's and a crank position sensor. I think both can be turned off in LT1-Edit. Search the lt1-edit archives....
Nayr
Mar 3, 2023 08:34 PM
93 RedBird
Nov 15, 2015 08:24 AM
fift5
11
Oct 1, 2015 10:31 AM
drt
Sep 27, 2015 04:39 PM
MDZ28
11
Sep 24, 2015 09:15 AM
