Usb and datamaster
Old Sep 18, 2005 | 02:01 PM
crazyfastbird93's Avatar
Usb and datamaster
Who uses a usb cable and datamaster. What version are of datamaster are you using? I cant seem to get the two to cooperate. I bought the cable from Moates.net and it claims to be compatible with datamaster.
Thanks,
Nick
Old Sep 18, 2005 | 04:13 PM
Z28barnett's Avatar
Re: Usb and datamaster
Thanks,
Nick
I have used datamaster and that exact cable. You have to go into the control panel and set the USB adapter to a port that the datamaster program can use. I think I have mine on com2. It was on com14 or some other crazy setting.
First you have to load the drivers from the CD rom.
There are detailed instructions with the cable on the CD rom, you need to make the change with the cable on the computer so it sees it.
Mine is Datamaster version 3.4.1 and the Moates USB cable.
Z28
Old Sep 22, 2005 | 04:39 PM
infinitebird's Avatar
I have also used Datamaster with the moates cable with no issues.
If you have the drivers installed correctly and the right port selected it should work.
Aug 24, 2015 06:41 AM
Bails098
Aug 17, 2015 05:15 PM
BIGRIG
Parts Wanted
Apr 28, 2015 07:56 AM
jkipp84
13
Jan 31, 2003 06:22 AM
NVR2QIK
11
Aug 23, 2002 05:33 PM
