Turn Off Security Light Via TunerCat
Old Sep 18, 2004 | 03:05 PM
Kryckter's Avatar
Is it possible to turn off the security light with TunerCat?
I have all the VATS disabled through tunercat but the security light is still on!
Is it possible to accomplish what I am trying to do?
Old Sep 20, 2004 | 09:10 AM
Valkyn71's Avatar
Re: Turn Off Security Light Via TunerCat
I was told by Bryan at PCM4less that the VATS system is totally seperate from the PCM and the only thing tuning can deactivate is the fuel pump cutoff.
Old Sep 20, 2004 | 04:28 PM
The VATS is what tells the light to come on, so I would say you would have to disconnect the light. The VATS does report to the PCM, but not vice-versa, AFAIK.
Old Sep 23, 2004 | 05:49 PM
Kryckter's Avatar
Thanks Shoebox,
Since I have the VATS disabled, could i still use a resistor and delete the light, Or will that method not work anymore?
Old Sep 23, 2004 | 08:57 PM
1fastlt1's Avatar
you could reactivate it and use the resistor and it would but i'm not sure about the other way around but it shouldn't hurt anything to try.
moparman
Mar 5, 2015 08:47 AM
Oncomingstorm22
Jan 22, 2015 07:15 PM
fpete1992
Dec 11, 2014 03:51 PM
blac94Z
Dec 2, 2014 12:09 PM
formula79
26
Aug 5, 2002 12:21 PM
