tunning help please newbie
Old May 29, 2008 | 09:32 PM
cmzfly93's Avatar
help!!!!!!!!
I have a 1993 camaro with a 355 motor in it which consist of, 9.3compression Srp -24cc blower pistons scat procomp 7/16 rods stock crank and arp main studs ported heads with 2.00 and 1.56 valves and a cam 224/236-114 installed at 110 icl and long tube headers and ported intake 42lbs injectors k&n cold air filter kit and a 1994 computer and wire harness installed tune is stock have not fired it yet and am not going to professional to have it tuned do have some experience on fords what should i all change to get afr right
have tunercat software and EE definition file please help
Old May 30, 2008 | 03:10 PM
Slick_Sammy's Avatar
if you've looked at all the tables and still don't know where to start, i would highly suggest starting with a mail order tune as a baseline. you can order one from the pros for like $75 and then datalog to get cheap updates. they email you the tune and then you upload it yourself. this would give you a good baseline to compare the stock to baseline mail order tunes and then maybe empower yourself to do the rest of the tuning on your own based on datalogging. that's how i would start. there are hundreds of parameters so no one is going to come on here and tell you exactly how to do it.
chuyz28
Jan 27, 2015 08:53 AM
Z28countrymama
Jan 22, 2015 02:50 AM
lt1camaroman93
Feb 5, 2003 06:18 AM
lastZ
Jan 12, 2003 05:29 PM
2000zee28
Jan 11, 2003 09:57 PM
