No response from PCM..
Old May 25, 2008 | 04:34 PM
flyinZ's Avatar
I tried to read my pcm, and I got this message"no response from pcm." Does anybody know what is wrong? My aldl cable? Wiring to the pcm? My old-*** HP laptop? Im about to freak out on this thing,lol. HELP!!!
I tried using Datamaster, and Im not getting any streaming data or anything. I've got some trouble codes that I need read, and both of my fans are on due to a particular code. This is always the luck I have with mail orders...
Old May 25, 2008 | 06:20 PM
What type of connection are you using - serial or USB?
Old May 26, 2008 | 02:10 PM
flyinZ's Avatar
USB and I got the cable from AlDl cables, a few years ago.
Old May 26, 2008 | 10:31 PM
And its a cable specifically designed for a USB connection? Have you ever used the cable before? Did it ever work?
Old May 27, 2008 | 12:32 PM
flyinZ's Avatar
Yes, the last time I used it was about a year ago, and it worked flawlessly..Different laptop/user.
Old May 29, 2008 | 09:40 AM
bobdec's Avatar
Have you assigned the correct com port. Assuming Windows/XP...Control panel, system, hardware, dev mgr, ports to see what port the cable is assigned to. Then Datamaster, record adl , setup, com port to set Datamaster to use that port ??
Old May 29, 2008 | 12:30 PM
flyinZ's Avatar
Yep, set everything to com port 3. Still nothing...
Old May 30, 2008 | 03:24 PM
bobdec's Avatar
Forgot to ask you about the driver, did you get a CD with the original cable, did you try reinstalling the driver on the new laptop ?
Old May 30, 2008 | 04:07 PM
flyinZ's Avatar
Yes, installed a driver from the companys' website.
Aug 24, 2015 11:04 PM
karpetcm
Aug 14, 2015 03:02 PM
whitehooptie
Jul 22, 2015 10:25 PM
94Form
Feb 10, 2015 11:23 PM
97 RedSS
Sep 23, 2002 07:34 AM
