Tuning totally in speed density on a MAF car.
Old Nov 19, 2003 | 12:34 AM
96z's Avatar
96z
Is it possible/feasible/worth the time to tune or run an originally equipped MAF sensor car in speed density mode. For example for what ever reason a MAF sensor couldnt fit into the intake ducting.
How would you tune purely with speed density?
Old Nov 19, 2003 | 01:57 AM
DOOM Master's Avatar
You would disable the MAF by using the ECM switch Speed Density Mode. Then you would have to tune the car by using the Volumetric Efficiency tables.
Old Nov 19, 2003 | 12:35 PM
JSK333's Avatar
Yep, as DOOM mentioned, that is how you tune it.
I tried it, and figured it's not worth it. Even after several times of VE Master, changes in weather really seemed to affect the tune.
Old Nov 21, 2003 | 02:14 PM
96z's Avatar
96z
Intesting, I never thought about the weather. Im guessing alot of dyno time would be involved also..
Old Nov 22, 2003 | 02:44 AM
InjectedSS's Avatar
Unless you have your own wideband setup it would be hell
Old Nov 22, 2003 | 11:05 AM
rskrause's Avatar
Moderator
I played with it for a while and decided it wasn't worth it.
rich Krause
Old Nov 22, 2003 | 09:08 PM
Yeah, VE is very dependant on the weather. Tuning VE is very difficult without a proper dyno/wideband/data logging setup, because you have to get it dead on. You'd be much better off using the MAF rather than tuning via VE.
Old Nov 23, 2003 | 12:24 PM
LT1RX7's Avatar
93+ RX7s work off of just speed density I think and they seem to do fine. They run off of just a map sensor if that's what we're talking about. The only thing that notice is most tuners tune at around 12.5-13.0 a/f. Maybe it's because it's a rotary, maybe to compensate for cooler/warmer climate.
Old Nov 23, 2003 | 11:09 PM
I'm not saying that you can't tune in VE (speed density, MAP sensor, whatever you want to call it), I'm saying that it is more difficult. MAF is very simple, because the MAF sensor does most of the work, you don't need to worry about what the volumetric efficiency is with a MAF car. But on speed density, it is the only thing you have to tune by. For a lot of people, speed density is the only way to go, especially those who didn't originally have a MAF system and those that have maxed out the MAF. But if I had the option, sticking with MAF is a better way to go.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
DirtyDaveW
Dec 1, 2016 05:37 PM
Dec 4, 2014 11:56 AM
Jul 4, 2005 05:00 PM
