Tuning Question
Old Mar 4, 2014 | 11:16 AM
mikes 95 Z28's Avatar
Smile Tuning Question
I have a 95 Z28 It came with some kind of tune.the previous owner put in, I want. to put in one of my own but i heard if you don't pull the old one out it will lock up. i don't think it will but i just want to make sure. also how do i get the tune out i don't have the obd tuner box. thank you in advance for your help. Mike
Old Apr 2, 2014 | 11:13 AM
LT1_383_Stroker's Avatar
Re: Tuning Question
1994 and 1995 are flash based. You don't have to pull the chip. You can tune with an ALDL cable (look up ALDLcable) or the new ALDL bluetooth adapters (not the OBD2 bluetooth adapters; look up red devil river or 1320 electronics). You will need some software for your laptop, probably tunerpro or tunercat. It automatically overwrites the old tune; I've never heard that you need to remove the old tune to not lock up the ECM. You probably do want to download the current tune to use as a baseline. Alternatively, you may find someone who has the stock tune file that you can use as a baseline. You can lock up the ECM or 'brick' it if you interrupt the upload process. This is where the laptop is sending the new tune to the ECM. If you mess with anything (mayble your laptop goes to sleep) you can trash your ECM. I think that is the only risk. Good luck!
DirtyDaveW
Dec 1, 2016 05:37 PM
AlaskaZ28
Dec 16, 2014 07:24 PM
AlaskaZ28
Dec 10, 2014 02:39 PM
AlaskaZ28
Dec 10, 2014 02:37 PM
nophix
Nov 30, 2014 10:26 PM
