TunerCat retry after getting dead PCM back...
Old Jan 22, 2003 | 02:13 PM
  #16
Dave 96TA's Avatar
roguedriver - where'd you get your PCM repaired? I need to send mine away and/or find a temp replacement.
Old Jan 23, 2003 | 02:28 AM
  #17
Dr.Mudge's Avatar
Originally posted by ablackcamaro
Why can't TunerCat just make software that will write to a PCM without first erasing it?
That is exactly how it works, it says OK dump your data I'm overwriting you. Basically, you trigger a certain address to begin the overwrite. However, if there is nothing there in the first place the PCM does not "boot up", and thusly you cannot COM with it.
Old Jan 23, 2003 | 09:54 AM
  #18
ablackcamaro's Avatar
That bootup thing makes sense to me now... I get that part... but if the second FLASH chip gets fried, and the first one is successfully programmed, then can the laptop communicate with the PCM? Will the car still run under these conditions, if only the second chip was fried?
Old Jan 23, 2003 | 11:29 AM
  #19
roguedriver's Avatar
Dave....
Dave, got my PCM repaired at AKMcables, the same place you get your cable from to do your programming. There are other places out there that can do it also. Check the links on AKMcables page, TunerCat, ect and you'll eventually find them.
Ken
Old Jan 23, 2003 | 12:22 PM
  #20
Roguedriver, when he repaired your PCM, did he socket it? I'm under the impression he has to remove the chip from the board anyway, so why resolder it back in? Might as well socket it, no?
Old Jan 23, 2003 | 03:59 PM
  #21
Dave 96TA's Avatar
Oh ok well then I'm on the right track...I emailed Andrew @ AKMcables yesterday about repairing my PCM so I guess I'll wait to hear back.
Nayr
Mar 3, 2023 08:34 PM
fift5
11
Oct 1, 2015 10:31 AM
drt
Sep 27, 2015 04:39 PM
MDZ28
11
Sep 24, 2015 09:15 AM
