tunercat pcm mem program error?
Old Dec 26, 2003 | 10:45 PM
Fbody1's Avatar
Exclamation tunercat pcm mem program error?
I went to re program tonight, everything went normal until it was finished, then it read . flash memory checksum error, and pcm memory program error(6) , then it read pcm memory aborted, why is it doing this?
Old Dec 27, 2003 | 12:56 PM
m0nk's Avatar
what version of tunercat are you running?
Old Dec 27, 2003 | 02:01 PM
Fbody1's Avatar
2.00 , I can not read the pcm or reprogram it , was working fine 9 or 10 month's , now this ?
Old Dec 27, 2003 | 10:33 PM
Fbody1's Avatar
ttt
Old Dec 29, 2003 | 07:09 PM
Schurters LT1's Avatar
Sorry bud you just killed your pcm better give madwolf a call don,t fell bad i killed 3 in a month
Old Dec 29, 2003 | 08:06 PM
Fbody1's Avatar
how is that possible , the car still run's like everything is normal?
Old Dec 29, 2003 | 09:17 PM
The same thing happened to me security code or somthing anyway....the car did everthing fine start,drive everthing just could not talk to the pcm anyway at all...what happened with mine the secerity for the pcm stayed on some how i asked tuner cat and he said he never say this before(i gave him my file)..ask madwolf if he can or a used pcm...
Old Jan 1, 2004 | 12:55 PM
Fbody1's Avatar
the pcm took the program , but the error code said that it did not , it read the program I was tring to read, but the error code said it did'nt, strange . I have a extra pcm ( from a impala) maybe I can redo all the table's so it will work on mine?
Nayr
Mar 3, 2023 08:34 PM
fift5
11
Oct 1, 2015 10:31 AM
drt
Sep 27, 2015 04:39 PM
MDZ28
11
Sep 24, 2015 09:15 AM
marlar98
Sep 19, 2015 07:53 AM
