tunercat-How do you make it run?
Old Dec 24, 2002 | 09:24 PM
  #16
oemfisystems's Avatar
tunercat flash utility
We've run into the read problem, many times. When that happens, just get the donor lt1 file from the diy-efi website, and use it to make a new program. We've got about 20 different lt1 calibrations that we use, and don't even read the old program anymore. One thing to make sure of is the battery voltage during the whole programming phase is 12.4-13.00 volts. SOMETIMES, the comm bus from the abs, etc, can cause a crash or problem, and removing those system fuses should solve that particular problem, if is the case. If you email me with your original calcode, I can send you the original cal file, if you'd like. Use the 4-digit code from the side of the box.
jim
Old Dec 24, 2002 | 09:26 PM
  #17
windows me
As a side note, I'd recommend strongly to use win98se, win2kpro, or XP. ME is one horrible OS in any case.
jim
Old Dec 26, 2002 | 10:36 PM
  #18
sweetassz's Avatar
Finally, good news!
Just put Windows 98 back in, actually just had to delete ME, Windows 98 was already set up as the base system.
I ran the flashread program and it down loaded the ecm program without any problems Also I ran the flash program right off the hard drive; I didn't have to down load it to disket first
Well next thing I have to figure out is how to upload my changes back into the ecm.
Oemfisystem, thanks for the input I will be taking you up on your offer. I would like to have the original file for comparison. My ecm has been recalibrated before.
Old Dec 27, 2002 | 10:53 AM
  #19
Just let me know-you are welcome!
jim
Old Dec 28, 2002 | 11:00 AM
  #20
sweetassz's Avatar
Re: tunercat flash utility
[QUOTE]Originally posted by oemfisystems
jim
[/QUO
The box you refer to is the ecm? I can't find a 4 digit code on it. Can you elaborate?
Old Dec 28, 2002 | 12:13 PM
  #21
Sure, the PCM calibration is identified with a 4-digit broadcast code, and it is located on the white sticker on the side of the PCM, located by the passenger hood hinge, on the f-body. On those it is all letters, starting with a "B".
jim
Old Dec 28, 2002 | 12:25 PM
  #22
sweetassz's Avatar
OK, just wasn't sure which code you needed. (BMFN)
You can send it to sweetassz@yahoo.com
Old Dec 28, 2002 | 12:48 PM
  #23
Comin' at ya.
Old Dec 31, 2002 | 02:20 AM
  #24
SlitherStang's Avatar
Turbo_Z, you have mail. I sent one to your hotmail account and one to you at the pcmforless address
I have used countless tuning programs for my mustangs. I wish we had something like what turbo_z offers for us mustang guys
YOu should give it a thought turbo_z, there is BIG bucks to be made in the Ford crowd! Every tuner we have is like greek, and very expensive!
F'n1996Z28SS
Aug 23, 2023 11:19 PM
InfernalVortex
Jan 17, 2015 09:35 AM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
