tuner cat( vol efficiency vs rpm vs map) w/ hotcam
Old Nov 26, 2003 | 07:58 PM
Fbody1's Avatar
did a comparison from my program in my car w/ hotcam , to a stock program, mine is mostly stock from like 85kpa at 2000 rpm to 2600 rpm 100 kpa , is this correct for a hot cam? both tables have a little bit done in the lower kpa's(like from 20 and the lower rpm's ) can anyone explain this to me ?
Old Nov 26, 2003 | 11:41 PM
DOOM Master's Avatar
The VE tables are only used if your MAF fails and the car goes into speed density mode. The hotcam most likely lowers the volumetric efficiency of the engine in those areas, hence the reason why it is lower. I wouldn't worry about it too much, very few people believe that the VE tables in any way effect a MAF car.
Old Nov 27, 2003 | 10:09 PM
InjectedSS's Avatar
WHAT HE SAID
The VE Tables ARE NOT used on MAF cars UNLESS the MAF is unplugged... Then that would take you into Speed Density mode..
DirtyDaveW
Dec 1, 2016 05:37 PM
HarleyZ28
Oct 5, 2015 06:23 AM
k1996z28
Apr 13, 2015 06:54 PM
rckrzy1
Aug 14, 2002 10:00 AM
