Tuner cat questions!!!!!
Old Jan 9, 2009 | 09:07 PM
BMD18's Avatar
Hey i have heard that turner cat was a good tuner for the LT1!! I was just wondering if i got this if you guys would help me out and give me some basic tips to tuning my 95 Z28 LT1 OBD1!!! You know give me the basic performace boost settings and if you guys could explain to me about the tuning process and explain what all the tuner cat can do for me!!!! Thank you Brian!!!!
Old Jan 9, 2009 | 09:53 PM
ak95ta's Avatar
You gotta be kidding me....Just like that? More Info needed.
Old Jan 9, 2009 | 10:39 PM
dookie454's Avatar
TunerCat is better but harder than LT1_Edit
Datamaster is a requirement.
It's as easy as comparing a stock tune in datamaster and Tunercat/LT1_Edit, mainly MAP based Timing and if your not using a MAF, then the VE Tables.
Example, a bigger cam creates higher MAP values, so you need to compare idle timing with stock cam to idle with new cam and move timing to new cam MAP tables accordingly, increase idle timing until it idles best. Fuel with a MAF should adjust, use VEMaster to tune VE tables.
Everything else is covered it hundreds of posts.
Old Jan 10, 2009 | 01:35 PM
sbs's Avatar
sbs
Start by googling "LT1 PCM tuning" "GM PCM tuning" and variants on that theme.
There are a number of web pages out there to get you started.
Old Jan 11, 2009 | 10:22 AM
bobdec's Avatar
BMD18, You're looking at a long term but not impossible task. I started self tuning about 1 1/2 years ago and I'm still learning. It will take a LOT or searching, reading and trial and error. I started with real basics, speedometer, fans, shift points (4L60E) and timing on a relatively stock set up as you have. Knowing my knowledge limits I purchased a mail order tune after I installed my cam. But I kept on progressing, downloaded some tunes through the forums and other members, used the good pieces, and moved on to more customized tuning for my expectations and driving needs. Since I started with TunerCat 'Tuner' and TTS 'DataMaster' I can't compare them to any other S/W, but they have provide me the ability to do anything I need to do with my setup. I would recommend them.
Old Mar 13, 2009 | 06:33 PM
BMD18's Avatar
(admin edited)
Last edited by JasonD; Mar 13, 2009 at 07:44 PM. Reason: Childish insults and "tough guy" threats removed
Old Mar 13, 2009 | 06:47 PM
Locking.
DirtyDaveW
Dec 1, 2016 05:37 PM
Dec 1, 2014 08:08 AM
tubby
Oct 13, 2003 09:16 AM
z28projects4ever
9
Jul 16, 2002 07:48 PM
jrp4uc
Jun 19, 2002 06:20 PM
