TTS Datamaster OBD1 Cable Tester Program
Old Jan 28, 2007 | 11:11 PM
2xLS1's Avatar
Is this cable tester program you can download from the TTS web site supposed to work for testing the AKM cables? I can't get it to work.
Old Jan 28, 2007 | 11:31 PM
EkS's Avatar
EkS
Yes, it does work for the AKM cable. I have an AKM cable and I used it to test my cable, and everything worked fine.
Old Jan 29, 2007 | 12:23 AM
2xLS1's Avatar
Reason I ask is I built my cable from the kit. I tried testing it with the TTS program and it failed every test. Naturally, I thought I did something wrong building the cable. I borrowed another AKM cable from a friend that I know works. I even read the program (using TC) out of his 94 Camaro with it and it even fails when running the TTS test program with his cable and the same laptop I used to read the program. I've been afraid to use the cable I built thinking it might have a problem, but now I'm not so sure.
Old Jan 29, 2007 | 10:32 AM
VinceTrifecta's Avatar
I wrote a cable tester also, for another forum member. Essentially it tests the reliability of the connection to the PCM by reading the PCM memory but it also performs detailed logging so if something doesn't work, we can narrow it down.
Please send me email if you want to try it out.
surreybrad
Sep 29, 2015 09:00 PM
navtool.com
Sep 24, 2015 03:30 PM
navtool.com
Sep 24, 2015 03:26 PM
navtool.com
Middle Atlantic
Sep 24, 2015 03:17 PM
marlar98
Sep 19, 2015 07:53 AM
