trans tuning issue
Old Jul 20, 2007 | 06:34 PM
  #16
jakesz28's Avatar
The factory tables lock up the torque covertor at 40mph at light throttle. Is that when it is locking up during cruising? If so and you dont like it just pay with the mph settings for the different tcc tables.
Old Jul 20, 2007 | 11:12 PM
  #17
red 95 z28 lt1's Avatar
thanks for helping me, i have to check this one out, i just dont have lockup at any mph in 4th.
also do you think that the temp sensor in the trans will affect the computer in the car and when it shifts too because it reads -40 deg i believe this was a trouble code for the trans. but this has been happening since before the pcm went out to pcm for less.
thanks again
Old Jul 21, 2007 | 11:01 AM
  #18
jakesz28's Avatar
The temp sensor not working will cause the tranny to use all the cold shift tables. My car will not go into overdrive until the car warms up some. When I leave to go to work in the morning I bet I'm 6-8 miles down the highway before it goes into overdrive. If I start it and drive thru town it is warmed up before I get on the highway and then it locks up fine.
Old Aug 16, 2007 | 02:43 PM
  #19
ssean92's Avatar
any one have a bin file I can compare, car wth 3000 stall 323 gears. thanks sean
Old Jun 29, 2008 | 06:07 PM
  #20
ok still having problems, so far i traced it down to a pressure switch which has the tft sensor in it, my wiring is good going to the trans im going to change the pressure switch and go from there, i also have to shift early from 2 to 3 because i will hit the limiter 1 to 2 is good tho
PCLZ28
Dec 24, 2015 05:19 PM
armedtrigger
Feb 24, 2015 08:30 PM
Jan 5, 2015 07:14 PM
rockync7
Jan 1, 2015 05:10 AM
