TPS % not reading 100% at WOT in scanmaster
Old Mar 23, 2010 | 09:18 PM
97 RedSS's Avatar
Anyone think of a reason the TPS % in Scanmaster would read 7.5 % instead of 100% at WOT?? My TPS voltage is showing 4.8v at WOT. Wierd thing is that it seems to read the correct % other than at WOT. I am getting a TPS high voltage code so I will have to slot the sensor to correct that, but I wouldn't think that would cause the issue I am seeing?? I will correct that problem first and maybe that will be my solution.
Old Mar 23, 2010 | 10:15 PM
MikeGyver's Avatar
Whats the voltage with the throttle closed? Does the voltage climb smoothly and without gaps as you open the throttle with the pedal?
Old Mar 23, 2010 | 11:17 PM
The high voltage code is based on exceeding 4.9V for more than 1 second. That's not likely a TPS adjustment issue. Its more likely to be the signal wire shorting (intermittent?) to the reference wire, or a short on the sensor windings.
Old Mar 23, 2010 | 11:33 PM
97 RedSS's Avatar
Injuneer, I'll email you a datamaster scan I did ealier today and let me know what you think. Seems to read % just fine up until it hits 4.8V. I never see it ago above 4.9V but it still throws the high tps voltage code.
Peytons'z
May 6, 2021 09:25 AM
DirtyDaveW
Dec 1, 2016 05:37 PM
edman
Jan 22, 2015 02:45 PM
z28projects4ever
9
Jul 16, 2002 07:48 PM
