Timing reduction issue
Old Feb 13, 2009 | 06:52 AM
95Blackhawk's Avatar
All,
Reprogrammed my car to reduce timing when the coolant got above 92 C as an experiment. On the table, I took out 4 degrees but upon using Datamaster, it showed anywhere from 11 to 8 degrees taken out. This is approximate because I have not analyzed at what RPM, etc. that each differnet timing was taken out.
Bottom line: seems the mystery timing was also taken out but that doesn't exactly correlate either.
I have reprogrammed to what I had before but have not datalogged as of yet.
What am I seeing?
Old Feb 13, 2009 | 11:59 PM
MikeGyver's Avatar
Tunercats? which table did you modify? ...keep in mind that lots of other tables are referenced as modifiers so it can be annoying to figure everything out.
Old Feb 14, 2009 | 06:59 AM
Yes, TC.
Modified the coolant vs map table.
Thank you,
Ben
Alex Barnes
Jan 24, 2015 10:21 PM
bossco
Nov 29, 2014 10:18 AM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
Snoman73
Nov 17, 2014 07:22 PM
