Timing Question
Old Oct 15, 2002 | 10:50 PM
BTLTGR's Avatar
Timing Question
I am wondering what base timing (idle) is and what you guys are running for full timing on an LT1 car..Thanks for any info you've got. Thanks
Old Oct 15, 2002 | 11:04 PM
95Blackhawk's Avatar
Re: Timing Question
You might want to check out a few sites that carry other .lt1 or .bin files and see what they have done.
http://www.webrats.com/pcmdummy/inde...wdir=/tunnings
From my readings, and looking at other files, I see a lot of non-modified timing tables or at the very most, a change of 2-3 degrees added across the board or in certain areas on LT1 cars. Personally, I have not fooled with mine as of yet since I believe that is where I will not see the most power increase. The most power I got was from WOT tuning AFTER I got my car running correctly in closed loop.
Ben
Old Oct 15, 2002 | 11:40 PM
BTLTGR's Avatar
Re: Re: Timing Question
Ben
Well from your readings or others what is the initial timing and w.o.t. Sorry your link loaded but with errors it said. I didn't copy it to my browser though. Thanks for the help I am trying to set up a timing table so I need to know a.s.a.p.
Old Oct 15, 2002 | 11:46 PM
timing maps are 3 dimensional based on MAP and RPM it is difficult to give you the info you are looking for because of that. The timing varies from 20 something to 40+ depending upon MAP and RPM.
I suggest you use what is existing.
Good Luck
Ben
Feffman
Oct 9, 2015 05:42 AM
sscott
Jan 17, 2015 04:30 PM
capebuf
Jan 13, 2015 07:22 PM
Queens94z28
Dec 20, 2014 09:11 PM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
