Strange tuning problems
Old Aug 5, 2004 | 06:52 PM
  #16
chucks97ss's Avatar
Re: Strange tuning problems
Originally Posted by SABLT194
If I lived in Houston I would become your very best friend in the whole world!
If you could simply tune this car for me you would become my very best friend in the world It's a customers car, and I'm at my wits end with it. LT1's are normally pud to tune. But this one is giving me nightmares! I didn't work on it today though just because it's too frustrating. I might try it again for the last time tomorrow. Thanks for all the help. Appreciate it much.
Chuck
Old Aug 5, 2004 | 10:00 PM
  #17
Dan K's Avatar
If I were you I would set the maf tables back to stock. Use them for tuning part throttle blm's if you choose, but I've found that if you get the injector constant right for the injector you're using and the fuel pressure you're running...that the stock maf tables work fairly well.
How much boost are we talking?
What size injector?
Is the fuel pressure regulator a boost referenced unit?
What ratio fmu?
Is an fmu even required with the amount of boost and injector you're running?
There are quite a few things that factor in here...
Old Aug 5, 2004 | 10:45 PM
  #18
chucks97ss's Avatar
What size injector?
What ratio fmu?
haha, it's got stock injectors (24#). I bet that's the problem
The customer purchased the kit, we only did the install. It's a Procharger D1SC, but has a big pulley. We haven't hooked a boost guage up to it yet, but I assume it's around 7 psi. Couldn't tell you what fmu it has, or what the ratio is. It's got a stock fuel pressure regulator as far as I know..
Thanks for the help Dan. You made the ol light bulb light up
Chuck
Old Aug 6, 2004 | 11:08 PM
  #19
Dan K's Avatar
I'd be willing to bet you're out of injector.
Find out what size injector you could go to and be able to get rid of the fmu.
Old technology. It works, but a big injector is the way to go IMHO.
Old Aug 6, 2004 | 11:49 PM
  #20
TriPinTaZ's Avatar
Originally Posted by bunker
I think at WOT before closed loop the PCM might be looking at the VE tables what do you think? cuz I know in open loop the PE table is ignored now LOL, I don't think tunning the MAF table will be any more accurate then the PE table unless there is a sertain area that you can't alter with the PE table then use the MAF to alter that A/F like say between the PE rpms.
Matt.
the OPEN LOOP vs TEMP vs MAP is the table refered to in WOT mode when in open loop. The VE tables also play a roll in all open and closed loop fueling but the specifics are complicated and not believed by some. And I do not want to start something here. Also since he boosting hes going beyond 100 KPA sooooooo the VE tables are very inccorrect and would be better if he didnt touch them.
Old Aug 15, 2004 | 01:06 AM
  #21
chucks97ss's Avatar
Well after a week of replacing parts, we're still in the same boat! Brand new SVO injectors didn't fix it, and a brand new Walbro 255 in tank pump didn't fix it. Fuel pressure goes from 45-60-back down to 45 (which is when it starts to cut out real bad.
Chuck
Old Aug 15, 2004 | 06:21 AM
  #22
SABLT194's Avatar
Starting to sound like you may have some ignition problems as well as the fueling problems that you've taken care of. You already know the biggies I'm sure.
1) Fresh Optispark
2) Fresh Wires
3) Colder Plugs - to avoid blowout
4) Bad MSD box if your using one - I've heard of a lot of problems with MSD's
Also: What kind of Duty Cycle are you seeing right before it starts breaking up now with the larger injectors? What the heck would cause the FP to drop back down to 45? Probably loosing boost when it starts to break up, then mainifold pressure drops, and thus FPR lowers FP. Just thinking out loud here.
Good luck.
Steve
Old Aug 15, 2004 | 07:54 PM
  #23
SABLT194's Avatar
1) Fresh Optispark
2) Fresh Wires
Good luck.
Steve
DirtyDaveW
Dec 1, 2016 05:37 PM
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
InfernalVortex
Jan 17, 2015 09:35 AM
97SSdude
Dec 31, 2014 07:43 PM
