Strange tuning problems
Re: Strange tuning problems
Originally Posted by SABLT194
If I lived in Houston I would become your very best friend in the whole world!
It's a customers car, and I'm at my wits end with it. LT1's are normally pud to tune. But this one is giving me nightmares!
I didn't work on it today though just because it's too frustrating. I might try it again for the last time tomorrow. Thanks for all the help. Appreciate it much.
Chuck
If I were you I would set the maf tables back to stock. Use them for tuning part throttle blm's if you choose, but I've found that if you get the injector constant right for the injector you're using and the fuel pressure you're running...that the stock maf tables work fairly well.
How much boost are we talking?
What size injector?
Is the fuel pressure regulator a boost referenced unit?
What ratio fmu?
Is an fmu even required with the amount of boost and injector you're running?
There are quite a few things that factor in here...
What size injector?
What ratio fmu?
What size injector?
What ratio fmu?
What size injector?
What ratio fmu?
The customer purchased the kit, we only did the install. It's a Procharger D1SC, but has a big pulley. We haven't hooked a boost guage up to it yet, but I assume it's around 7 psi. Couldn't tell you what fmu it has, or what the ratio is. It's got a stock fuel pressure regulator as far as I know..
Thanks for the help Dan. You made the ol light bulb light up
Chuck
I'd be willing to bet you're out of injector.
Find out what size injector you could go to and be able to get rid of the fmu.
Old technology. It works, but a big injector is the way to go IMHO.
Originally Posted by bunker
I think at WOT before closed loop the PCM might be looking at the VE tables what do you think? cuz I know in open loop the PE table is ignored now LOL, I don't think tunning the MAF table will be any more accurate then the PE table unless there is a sertain area that you can't alter with the PE table then use the MAF to alter that A/F like say between the PE rpms.
Matt.
Matt.
Chuck
Well after a week of replacing parts, we're still in the same boat! Brand new SVO injectors didn't fix it, and a brand new Walbro 255 in tank pump didn't fix it. Fuel pressure goes from 45-60-back down to 45 (which is when it starts to cut out real bad.
1) Fresh Optispark
2) Fresh Wires
3) Colder Plugs - to avoid blowout
4) Bad MSD box if your using one - I've heard of a lot of problems with MSD's
Also: What kind of Duty Cycle are you seeing right before it starts breaking up now with the larger injectors? What the heck would cause the FP to drop back down to 45? Probably loosing boost when it starts to break up, then mainifold pressure drops, and thus FPR lowers FP. Just thinking out loud here.
Good luck.
Steve
1) Fresh Optispark
2) Fresh Wires
Good luck.
Steve
