Speed Density?
Old Jan 5, 2004 | 04:04 PM
InjectedSS's Avatar
Speed Density?
When I unplug the MAF it will make the car run in speed density mode BUT will it throw a SES light? Then I have to CHECK Speed Density in tunercat correct? Or does it even matter to have speed density selected in the ECM SWITCH table?
Old Jan 5, 2004 | 06:10 PM
Dan K's Avatar
Pretty sure you'd have to check speed density.
Old Jan 5, 2004 | 07:40 PM
TriPinTaZ's Avatar
if u check speed density it will tell the PCM to not look for your MAF. Then you wont see a SES light.
Old Jan 5, 2004 | 08:41 PM
Buttercup's Avatar
You just told yourself the answer
If you unplug the MAF the car will run in speed density mode (since there is no MAF) and it will also throw a code (since there is no MAF)
If, for whatever reason, you want to run speed density simply change the speed density switch as you already suggested. Keep in mind that tuning an SD engine system is MUCH more intensive (see sig).
If there's nothing wrong with the MAF I see no reason to go SD.
Old Jan 5, 2004 | 09:27 PM
InjectedSS's Avatar
Exactly what I was thinking but wanted to be completly sure
thanks guys
DirtyDaveW
Dec 1, 2016 05:37 PM
May 8, 2015 11:30 AM
3TAS4ME
Apr 15, 2015 02:24 PM
DirtyDaveW
Mar 15, 2015 07:01 PM
Jul 4, 2005 05:00 PM
