SES light still on!!!
Old Jun 27, 2005 | 02:53 PM
LPE_wannabe's Avatar
Exclamation SES light still on!!!
OK...my SES light keeps coming on and going off every couple of days and it says its my O2 sensors...I figured since it comes on and goes off that it couldn't actually be my O2 sensors so i thought it was the Granatelli MAF making my car run lean and the guy at Thunder Racing said that could be since it goes off...so i buy a stock ported and polished MAF and cleared the comp. and it still comes on!!! Could this actually be the O2's???
Old Jun 27, 2005 | 03:45 PM
Joe 97RA's Avatar
Re: SES light still on!!!
It would be helpful to know exactly what code you are getting. Just an SES light doesn't tell anything.
Old Jun 27, 2005 | 04:04 PM
2001NBMZ28's Avatar
Yes, list your code(s). A vacuum leak can also make you run lean. P0171/P0174?
Old Jun 27, 2005 | 09:29 PM
how do you get those code numbers???
Old Jun 27, 2005 | 09:59 PM
DieKnow's Avatar
You need a scan tool. Or I should say a "code reader" because that is about all some scan tools that are sold these days are.
There are also some very nice tools out there. How much do you want to spend?
Old Jun 28, 2005 | 07:04 AM
moparman's Avatar
If your car is the '98, go to Autozone and have the codes pulled. Be sure to remember the exact code number(s).
Old Jun 28, 2005 | 07:20 AM
matt65's Avatar
Yeah, Checking the codes will be the most direct route to go. I bought a cheap puller for like $20 shipped from a member on the board. Very basic, but lets me know what the car is upset about. Don't just throw parts at it. Getting away from the aftermarket MAF was a good move. Post the codes once you have them pulled. I will be interested to see what they are.
Old Jun 28, 2005 | 11:44 AM
will do...i'll go get them read on my lunch break and i'll post them afterwards since i have nothing else to do at work lol
Old Jul 8, 2005 | 11:28 AM
Exclamation Re: SES light still on!!!
I finally got the codes...there's 4 different ones...P0133, P0135, P0153, P0155...so what do these mean??? Thanks!
Old Jul 8, 2005 | 02:03 PM
Tails's Avatar
P0133 Heated Oxygen Sensor (HO2S) slow response Bank 1 Sensor 1
P0135 Heated Oxygen Sensor (HO2S) heater circuit Bank 1 Sensor 1
P0153 Heated Oxygen Sensor (HO2S) slow response Bank 2 Sensor 1
P0155 Heated Oxygen Sensor (HO2S) heater circuit Bank 2 Sensor 1
Yep I'd say it's the O2's...
Oh and bookmark Shoebox's site..It's like google for F-Body's...
http://shbox.com/page/index.html
Tails
Old Jul 8, 2005 | 04:20 PM
so none of those codes could be cause by a vacuum leak right??? i just wanna make sure before i buy 2 $80 O2 sensors...thanks a lot
Old Jul 8, 2005 | 04:57 PM
The ones for the "heater circuit" indicate that the heater elements in the sensors are not working. That could be a fuse or wiring problem as well. And, the heaters not working could be causing the "slow response". I think its safe to say it has nothing to do with a vacuum leak. Check out the power supply to the heaters.
If you include basic data like the year of your car in your "signature", it makes it easier for people to help you. No one wants to have to go to the link in your website when you could just include the info up front. The easier you make it for people to help you, the more likely you are to get a response, and the more likely the response is valid for your specific car.
Old Jul 10, 2005 | 05:15 PM
my bad...i have a 98, 6M with an ORY and LTs with O2 sims in back it is possibly tuned with a hypertech, and a ported/polished MAF...the light would go on and of for days at a time when i had the Granatelli MAF but now that i have the stock MAF it stays on???
Dzmaro
May 7, 2015 09:33 AM
Gtpguy
Jan 26, 2015 04:50 PM
sleeperZ96BT
Jun 5, 2005 09:33 PM
Rich_z28
Sep 13, 2002 03:35 PM
Z28Wilson
Aug 1, 2002 04:27 PM
