Security Light Stays on
Old Jan 10, 2006 | 07:30 PM
yacka's Avatar
Hi Folks,
I have 94 Z28 Camaro. At times when I go to start the car, security light comes on then stays on. The car is imobilised and will not start for approx 5-10 minutes, after which it will allow me to have another go. In most cases it will start, odd occasions will not. I suspect that it has something to do with the security key ( eg pellet resitor on key) or possibly the ignition tumbler itself. I have tried different keys in it whilst the security light has been activated but the imobiliser is still activated. Can I point the finger at the ignition tumbler as being the likely problem. Is there a way around the problem eg. have heard of possible bypass fix. eg. determine resistor value of key then wire this value resistor into circuit. Not real clear where to find wires. If this is possible must be a way of having this resitor in circuit and utilising a two way swith to bring imobilisor in and switch out when key/ignition switch plays up - in otherwords I can control imobilisor not it control me regards "going nowhere" Yacka !!
Old Jan 10, 2006 | 08:03 PM
ExStyle's Avatar
Re: Security Light Stays on
I had the same problem in my car you have to replace the whole key and lock assembly, go to a local dealer and order it. I believe mine was $50 be shore to bring your serial number or they wont sell you one. And when installing it buy yourself a steering wheel lock plate tool. Good luck!
Old Jan 10, 2006 | 08:28 PM
The general tech forum is filled with security light threads. A search there should help you out.
Old Jan 10, 2006 | 10:49 PM
cpt_bimes's Avatar
i just found every thing you need to solve this problem on this man's site^
and if you get tired of the light..just put a piece of black electrical tape over the light.
moparman
Mar 5, 2015 08:47 AM
STR FTR 1
3rd Gen / L98 Engine Tech
Feb 10, 2015 10:36 PM
Oncomingstorm22
Jan 22, 2015 07:15 PM
fpete1992
Dec 11, 2014 03:51 PM
blac94Z
Dec 2, 2014 12:09 PM
