Security light?
Old Aug 8, 2002 | 06:06 AM
CrAkD X 95TA's Avatar
Post Security light?
i have a 95ta the "security" light used to come on with the rest of the lights on the dash when starting the car then would go off now it stays on the entire time the car is on any idea on whats causing this???
Old Aug 9, 2002 | 07:26 PM
Dr.Mudge's Avatar
Post
The resistor in your key is full of crud, and/or the workings of your lock tumbler in the steering column are going out.
Take it to a dealer to check out, and/or try alcohol on the key.
Old Aug 11, 2002 | 08:18 PM
96z's Avatar
96z
Post
I got that light too.
96 black Z28 A4
GTP heads, GTP cam, bolt ons...
Mattucci Motorsports WNYFA FLFB
So far...12.7@108...need more practice...
The Z
Old Aug 11, 2002 | 09:12 PM
rckrzy1's Avatar
Post
<font face="Verdana, Arial" size="2">Originally posted by Dr.Mudge:
</font>
Dealer, man are you rich or what? It can be bypassed, do a search for it, Or program it out.
Adam in Hurst TX
95TA M6 Borla Cat Back
!TB,!MAF,Ripper,Tuner Cat
HP160, !UD pulley,CAI,
24# SVO
Best 1/4 13.79 101.4
Old Aug 12, 2002 | 01:05 PM
Dr.Mudge's Avatar
Post
I had mine programmed out via Tunercat, no I'm definately not rich. If you want it fixed though then you have to take it to a dealer for a new tumbler and/or set of keys, depending what the issue is.
Old Aug 12, 2002 | 09:26 PM
Post
</font>
thanks man....no one ever replys around here....after i get the car back from the "brake" dilemma ill try the alchohol a light aint worth going to the dealer tho.
Old Aug 12, 2002 | 09:37 PM
Dr.Mudge's Avatar
Post
So long as it only remains a light, and not an eventual "car wont start"... If you have any Tunercat friends it can be programmed out, I think the tumbler costs a couple hundred with the labor, Tunercat + cable would run less than that.
Good luck
Old Aug 14, 2002 | 06:07 PM
dayusmc's Avatar
From: Stationed at Camp Lejeune, N.C. (But Going Home SOON!)- From New Jersey
Post
My friend had the same problem! He just took his to the dealer(Jacksonville, NC) and they charge hom $275. $125 parts, $150 labor. Like they said you can just bypass it. There are 2 ways of doing this. Program it out of the ECM (but the light will still stay on in the dash) or put a resistor in line. If you want to know how to put the resistor in email me and I will explain how to do it.
KYLE P. DAY-SERGEANT USMC
97 Trans Am with minor mods.
EMAIL: dayusmc@marinecorps.com
moparman
Mar 5, 2015 08:47 AM
Oncomingstorm22
Jan 22, 2015 07:15 PM
fpete1992
Dec 11, 2014 03:51 PM
blac94Z
Dec 2, 2014 12:09 PM
JasonD
Jul 15, 2002 02:17 PM
