SD Mode and Fuel Trim
Old Oct 25, 2005 | 11:36 AM
Zero_to_69's Avatar
Car: 1996 3.8L Camaro
Speed Density mode enabled; the computer ignores the 02 sensors.
The 02 sensors will still produce an output.
The question is:
Will the Air/Fuel ratio be adjusted via short, or long term trim immediately
or
Will the computer learn over time and adjust ratios as the computer goes
into SD mode again?
I'm thinking the latter. From what I understand the fuel tables in SD mode
use the MAP sensor and RPM to determine AFR. I don't believe there is any
instant correction for fuel ratio.
Can anyone confirm this?
Thanks!
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
Heathen1
Jan 2, 2016 04:27 PM
maybe2fast
Mar 16, 2015 11:59 AM
cmdeshon
Dec 12, 2014 10:51 PM
