ALDL ports on V8 & V6 cars
Old Oct 24, 2005 | 09:10 AM
mongse_1's Avatar
Is there a difference between the pins on the ALDL between the V6 and V8 cars? I've got a conversion car (originally V6, now a V8) that needs tuning and I can't get a connection.
BTW, it's a 1994 OBD-I car.
Old Oct 25, 2005 | 03:00 PM
95wannabe's Avatar
Re: ALDL ports on V8 & V6 cars
I would have to say no... I did an LT1 swap an used the ALDL ports according to the instructions. I didn't have any software ahead of time to talk to the V6 tho.
Old Oct 25, 2005 | 03:15 PM
There are some differences, but the A (ground), M (serial data) and B (diagnostic) terminals are in the same place. If you have done a conversion, you need to make sure the PCM connections are getting to these pins on the DLC.
1994 LT1 PCM
PCM**DLC
D20 -- B
D30 -- M
Old Oct 25, 2005 | 04:20 PM
mongse_1's Avatar
Thanks for the assistance. I'm thinking about pulling out the wiring diagrams and just patching in near the ECM instead of the plug. I *think* the plug may be in upside down (no cover on the plug, just the terminal block), but nothing good ever comes from me trying to "think". I should only need the 3 wires to read, correct? I did connect using Datamaster and did a COM test, but when I tried to read the VIN, it lost COM. Supposedly, there's a Hypercrap program already loaded into the ECM, but that shouldn't affect connections.
Noenav
Mar 1, 2019 07:38 AM
oldschool
Feb 9, 2016 09:21 PM
MadMav
Feb 6, 2015 11:02 PM
bandit383lt4
Dec 21, 2014 09:12 PM
USAirman93
Nov 24, 2014 03:37 PM
