Run A/C without PCM?
Old Sep 1, 2004 | 03:03 AM
mmmchickenboy's Avatar
This question pertains to a 1994 - 1996 Camaro Z28 (LT1): Would it be possible to retain the use of the air conditioning system if the PCM is removed? I was contemplating a carbureted intake swap and was wondering if I would still be able to use this system if the computer is non-functional.
i was looking at a service manual and there are five wires that go into the PCM that are relevant to the A/C system:
A/C Request Signal
A/C Clutch Status
A/C Clutch Control
A/C Pressure Sensor In
A/C Evap Temperature Sensor In
or should i just keep the PCM in the car just to run the A/C and to keep my factory gauges functional? i want to retain the factory gauges to keep things looking clean and stock.
Thanks!
Old Sep 1, 2004 | 09:33 AM
tjwong's Avatar
Re: Run A/C without PCM?
A/C Request Signal
A/C Clutch Status
A/C Clutch Control
Thanks!
You just answered your own question. But why would you want to go back to an antiquated carburetor
HectorM52
Jul 30, 2017 11:46 AM
DirtyDaveW
Dec 1, 2016 05:37 PM
HectorM52
Jun 23, 2016 08:42 PM
Jan 5, 2015 07:14 PM
AlaskaZ28
Jan 1, 2015 12:30 PM
