quick ls1 ecm question
Old Feb 1, 2005 | 06:18 PM
kandied91z's Avatar
is there a difference between the 98-02 ecm computers. is any one year better to work with then another?
can you run a 1999 ls1 with an 00 computer, mix and match for example?
Old Feb 1, 2005 | 07:16 PM
madwolf's Avatar
Re: quick ls1 ecm question
There are several editions of LS1 PCMs.
97 Corvette LS1 PCM
98 F/Y body LS1 PCM
99-00 F/Y body LS1 PCM
01-03 F/y body LS1/LS6 PCM
All these have different part numbers and a 98 PCM will not work on a 99 or newer car and vice versa.
You can switch a 99 PCM in a 00 and vice versa, provided you flash it with the correct calibration.
Same goes for 01-03 PCMs.
As far as I can tell, 01-03 PCMs are pretty much the same thing as a 99-00 with a newer calibration, so you should be able to interchange those as well. As for using a different year PCM on your car, there is really no advantage to it.
94Form
Feb 10, 2015 11:23 PM
jayblev95
Track Kill Stories
Jan 15, 2015 07:48 AM
97SSdude
Dec 31, 2014 07:43 PM
4586
Dec 31, 2014 02:21 PM
ChrisFrez
Nov 23, 2014 10:33 AM
