Ques about tps volt vs tps %
Old Jul 9, 2007 | 08:43 PM
wicked_95z's Avatar
Here's the thing. At idle, the tps voltage is .69 vdc but it shows 13% throttle according to datamaster. If I turn the car off and restart it everything is fine. Is there a calibration that needs to be done? THanks
Old Jul 9, 2007 | 09:10 PM
stereomandan's Avatar
http://shbox.com/1/4th_gen_tech2.html#iac_reset
That might help. Not sure if it is your problem though.
Dan
Old Jul 10, 2007 | 04:43 AM
wicked_95z's Avatar
Yeah, I knew there was an IAC reset but my IAC is fine. Its just my TPS that seems screwy but thanks
Old Jul 10, 2007 | 07:47 AM
Dave1980's Avatar
I have not done this, but there is a way to slot the tps sensor holes, to offset it slightly. That is what your going to need to read up on.
Old Jul 10, 2007 | 01:33 PM
Oops, I don't know what I was thinking. I must have had the IAC on my mind. Sorry about that.
Yes,
Old Jul 10, 2007 | 04:02 PM
wicked_95z's Avatar
Its all good.
The TPS sensor is slotted. Thats how I was able to get it down to the .69 vdc.
Old Jul 10, 2007 | 07:45 PM
Is something keeping your throttle blades from closing, like the throttle blade screw? At 13% throttle, I'm at 1.02V. At closed throttle, I'm at 0.59. Do you know your IAC counts at idle?
What is your idle speed?
Dan
Old Jul 11, 2007 | 05:08 AM
wicked_95z's Avatar
My IAC counts are right around 60. When I start it up and the TPS says 13% and .69 vdc, it idles about 12-1300. When I shut it down and restart it making no changes, everything is normal. 0% TPS and .69 vdc and the idle is 850-900
Old Jul 11, 2007 | 12:25 PM
TQdrivenws6's Avatar
I always shoot for .45-.55v on the TPS myself, not sure if that is causing the problem though.
Old Jul 11, 2007 | 02:32 PM
mdenz3's Avatar
How are you getting .55v on a .5v referance cicuit?
Check your TP sensor with an ohm meter from closed throttle to WOT, make sure the sensor its self is good. make sure the sensor is properly engaging the throttle blade shaft. Did you have this problem before you slotted it? or did it start as a result of slotting it?
Old Jul 11, 2007 | 05:17 PM
The TPS reference circuit is 5.0V. The reference voltage does not limit how low the closed throttle voltage can go. That's the result of the amount of resistance in the circuit with the sensor in the "closed" position.
Does sound like the sensor may not be indexed to the blade properly. Might be worth checking, then clearing the PCM and trying again. Anything above 0.20V and below 0.90V at closed throttle startup should be recognized by the PCM as 0% TPP.
Old Jul 11, 2007 | 05:20 PM
mdenz3's Avatar
5.0v not 0.5 brain fart my bad.
Old Jul 11, 2007 | 06:00 PM
wicked_95z's Avatar
I have a new sensor on and this is the first time I have seen it. I will check to make sure it is positioned properly
Old Jul 27, 2007 | 10:20 PM
wicked_95z's Avatar
Well after fixing some other issues I was able to dig into the TPS but came up with nothing. I pulled the TPS and reinstalled it. Reset the closed voltage to .67vdc. I also switched out PCM with the same tune I have been running for a year and it does the same thing. About the third I start it up is when everything goes back to normal. I start it once and it idles high and throws a low tps volt code. Shut it down and start it up again; same thing. I usually let it run about 30 seconds each time. The third time I start it up everything is fine again. I want to say it's right about the time the car starts to warm up is when everything goes back to normal. Any ideas?
Old Jul 27, 2007 | 10:48 PM
Could be something sporatic in the TPS wiring, I suppose. It indeed seems odd that the voltage reading stays the same, but the % the PCM translates it to is not always the same. Try adjusting for a lower closed throttle voltage and see if there is any change.
