Problem with starting '95 lt1
Old Oct 29, 2009 | 08:01 PM
fakebuttcheeks's Avatar
Angry Problem with starting '95 lt1
Stopped car to put gas in, went to start back up, turned key to on postion, gauges did not move, but all electronics worked (lights, radio, wipers...), and the car would not crank over. Eventually, I have no idea how, the car started cranking, would fire up and immediately shut off. The only time it will stay running is if you hold the key all the way forward like you are trying to start it and hold the gas pedal down, as soon as you let off of the key it shuts back off. Checked fuel pump, its working, changed fuel filter, and was still doing the same thing. Went to dealer, got new ignition switch and a new key to go with it, installed, and still getting the same results. Starting to get frustrated, any suggestions??
Old Oct 30, 2009 | 06:59 AM
Sounds like you got a new key cylinder and not an ignition switch. Hope you got a key with a pellet to match your old one or you will have PassKey problems added to those you already have.
The igntions switch is on the lower part of the column and sounds like your problem.
http://shbox.com/ignsw/ign_switch_repl.html
Old Oct 30, 2009 | 06:17 PM
Dammit, now i sound like an idiot....lol...yes the cylinder is the part that i changed not the ignition switch, got a tip from somebody today to try that, so that is my next step tommorow, hope it works...im new to the camaro world, i just bought this car about a month and a half ago, so any ideas will definently help. And yes, I did get a new key with the cylinder. Thanks man.
Noenav
Mar 1, 2019 07:38 AM
97SSdude
Dec 31, 2014 07:43 PM
Jul 4, 2005 05:00 PM
1LEThumper
Jul 14, 2003 12:45 PM
slothgrant
Aug 22, 2002 03:01 PM
