Plz explain cat over temp
Old Oct 4, 2007 | 05:31 PM
JWS6's Avatar
what does it mean and how should I change the values here. My cats are gutted and I have sims installed.
Old Oct 4, 2007 | 06:53 PM
Are you getting some sort of code that is bothering you?
Old Oct 5, 2007 | 12:10 AM
JWS6's Avatar
no codes here shoebox it was just suggested that I change their values and I'm trying to figure out which way I need to go.
Old Oct 5, 2007 | 07:20 AM
I have never heard anyone talk about it. Who suggested changing the values and why? Maybe they can tell you what you need to modify.
Old Oct 5, 2007 | 09:43 AM
2xLS1's Avatar
Lean A/F ratios cause cats to run hot and burn themselves up. When the PCM thinks the cats may be getting too hot, it adds fuel to richen up the A/F mixture in an attempt to save the cats. If your cats are gutted, there is no reason to leave it enabled. If you are using TC OBD2 Tuner, there is a parameter for Min Coolant Temp For COT. Just set that value to a high value that you will never reach to disable COT.
Old Oct 5, 2007 | 11:24 AM
JWS6's Avatar
thanx and YOU taught shoebox something. Doesn't happen all too often
Old Oct 5, 2007 | 12:59 PM
I stick around here to learn, too. Programming has so many parameters, it's hard to keep up. I don't mess with it too much. I did see the A/F ratio setting for the cat temp. I guess it makes sense.
Old Oct 5, 2007 | 03:30 PM
JWS6's Avatar
I was just playing and thanx for the help again guys
Beave2780
Jun 11, 2015 07:57 PM
May 21, 2015 01:04 PM
spearous
Jan 12, 2015 11:03 AM
cmdeshon
Dec 27, 2014 10:06 AM
Notford95
Aug 20, 2002 01:46 AM
