Please help with the programming for my TC!!
Old May 31, 2005 | 11:27 PM
Tair's Avatar
i just installed a new TCI 3000 torque converter on my 94 Z28 (OBD1) and i have the infamous high-stall problem. (Car shifts from 1st to 3rd at WOT, and doesn't disengage 3rd until you shut off the car and restart it) I've already asked Madwolf and PCMforless to help me out with the problem...I bought tunes from both of them....neither of them worked. I understand that Ed Wright has a true fix for the solution, but I don't have enough $$ right now to buy ANOTHER tune yet. I need to know if anyone has found a workaround for this problem OTHER than the Ed Wright tune....if no other solution exists, I'll have to go that route. PLEASE help me!!
Old Jun 1, 2005 | 12:40 AM
Alvin@pcmforless.com's Avatar
Re: Please help with the programming for my TC!!
Bryan has a fix for it, if he gave you the tune with the fix in it you might need to start looking for something else wrong with the car. Or at least let him know it didn't fix it.
Old Jun 1, 2005 | 12:58 AM
madwolf's Avatar
I already explained that the problem is not in the tune. I guess it will take a 3rd tuner to come to the same conclusion...
Old Jun 1, 2005 | 03:22 AM
Tair's Avatar
I didn't mean to put-down either of your programming services...I'm just very frustrated as to not being able to find a solution to my problem. I have already double-checked the installation of the TC and everything appears to be fine. I have the same problem as this guy:
http://web.camaross.com/forums/showt...+stall+1st+3rd
However, in my case Bryan's fix did not work...a few others have also posted that the fix does not always work, and they end up switching to OBDII...which I HOPE I don't have to do.
revrider
Cars Wanted
Apr 5, 2016 10:06 AM
MDZ28
11
Sep 24, 2015 09:15 AM
marlar98
Sep 19, 2015 07:53 AM
FredM
Aug 14, 2015 01:49 PM
whitehooptie
Aug 10, 2015 07:02 AM
