Please Help! Myriad Of Computer/electronic Questions!!!
Please help a camaro novice! My 93 camaros' airbag light is staying on from the time it is started to the time it is shut off.
The fan is kicking on after the engine has been running for about thirty seconds and is immediately followed by the service engine light coming on. Both fan and service engine light remain on until the engine is shut off. Whats weird is that the fan just used to come on when the engine was at a higher temperature.
Any help will be greatly appreciated! Thanks, John
Your car is setting a code and the fans will kick on and stay one for as long as there's a service engine light. Luckily, your car is a 93 and you can use the paperclip trick to check your codes. Stop by Autozone and they'll check it for you.
dluna333
15
Mar 13, 2015 12:30 PM
jasonduaine
Mar 7, 2015 09:44 AM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
Hurin
Dec 13, 2014 07:38 PM
