Pcm tunning for Fuel press?
I have installed a Walbro255lph pump and have a fuel press problem that a adjustable reg isnt helping either! can a tune help this high presseure prob?
82-83psi on idle!!
Thanks!
82-83psi on idle!!
Thanks!
Re: Pcm tunning for Fuel press?
You can tune for some difference in fuel pressure, and I would say that you could tune to compensate for most of that difference, but that doesn't change the fact that you DEFINITELY have a problem there! Tuning around that is just going to make a potentially serious problem.
Even if you get it tuned so that it runs better, you risk the injectors going static on you at such high pressure...
Originally Posted by LWillmann
you could lock them open or closed, and either way it's bad.
either way would not fix a thing. it wouldnt even compensate for anything
Thanks guys!
I found out that my REG was defective and my shop is getting me a new one free of charge.
Originally Posted by Dan K
Aren't the Aeromotives good for the diaphragm rupturing?
I have had my Aeromotive AFPR for 4 years now and no problems so far. What do you guys like to use for base fuel pressure on an LT1? I just bought a new Sunpro fuel pressure gauge to verify mine, and it was like 48psi with the vacuum hose on, and 54 off. I brought it down to about 38 with vacuum, and 44 with it off. Havent test driven it yet, but it sure hasnt helped my split BLM problem at idle
Nick
Nick
!!!TED!!!
Aug 27, 2002 05:41 PM
helps to have an electric fuel pressure guage inside the car at all times
