PCM Identification
PCM Identification
I have 2 pcm's in front of me that all have the same p/n and are all OBD1's but, they have different numbers between the 2 astrics. I need to know which pcm is for a 6speed and which is for an A4. Thanks
Re: PCM Identification
There should be another 8 digit number besides the one between the asterisks unless the extra label got lost. If you list those numbers, I'll be able to tell you which one is which.
*86BKNAK032730F6F*
#2:16188051 BKNA
*86BKNAK040244K2E
#3:16188051 BMFP
*86BMFPK15046B7YF
Although those are not the numbers I asked for, I have been able to trace them for you. First two correspond to a 95 6 speed F-body with 3.42 gears and no speed limiter. (that is if the tune in them hasn't been altered)
Last one corresponds to a 95 A4 2.73 car with no speed limiter.
Nayr
Mar 3, 2023 08:34 PM
