Pardon My Ignorance but . . .
Old Nov 12, 2003 | 03:42 PM
Janny's Avatar
I'm planning the 4l60e to t56 swap, and I have Lt1 Edit.
I am led to believe that I simply upload any file from a t56 equipped f-bod into my pcm. Then download it, modify timing fueling maps etc, then reload with the new values.
Is this correct?
Old Nov 12, 2003 | 03:54 PM
madwolf's Avatar
Correct.
You should use a 95 flash though.
If your car is pretty much stock, all you'll have to do is just modify for the gears. If you have changes to your programming done, then copying and pasting the timing and fuel tables should work just fine. Sometimes manuals like a little less timing, so if you'll be getting some knock retard, keep that in mind.
Old Nov 12, 2003 | 04:20 PM
Janny's Avatar
Thankyou for that info Madwolf!
I've got a 94 flash. Will that be alright do you think, or will it likely cause problems?
Old Nov 13, 2003 | 01:09 AM
madwolf's Avatar
It's best to use a 95 flash because the 95 has upgraded engine calibration tables.
I emailed you what you need though.
Old Nov 13, 2003 | 09:20 AM
1fastlt1's Avatar
I just completed the swap on my 94! Man what a great feeling! I ordered my cable this morning and will be getting the LT1Edit software soon. Madwolf cna you send me the 95 Flash as well so I can start off right
Also any tips on where to get started as far as tuning the engine goes?
Richard
Old Nov 13, 2003 | 09:36 AM
madwolf's Avatar
Since you have a 94, you need a 94 M6 flash... and I sent you one.
Old Nov 13, 2003 | 10:14 AM
Janny's Avatar
You are the MAN, Madwolf!
Any idea what is different in the "latest" GM 95 flash, from what the original was?
Old Nov 13, 2003 | 10:20 AM
madwolf's Avatar
The 95 6 speed only went through 1 update. They fixed something related to EGR in the newer release.
Automatics typically go through more updates, especially 94s.
Old Nov 13, 2003 | 10:42 AM
Janny's Avatar
I've got my egr blocked off. Will I be affected in any way? I know it doesn't seem likely, but I thought I'd ask anyway.
Old Nov 13, 2003 | 10:44 AM
madwolf's Avatar
No, just disable the EGR code.... I think on a 95, it won't set a code anyway.
Old Nov 13, 2003 | 08:08 PM
1fastlt1's Avatar
Thanks Madwolf! For some reason i thought when reading janny's post his car was a 94 i now see it is a 95
whitehooptie
Jul 12, 2015 06:10 PM
Carlos01SS
Apr 11, 2003 09:40 AM
SERENAs Z
West South Central
Mar 29, 2003 09:38 AM
WS6Mark
Mar 25, 2003 01:31 PM
therealmagyver
N2O Tech
Feb 10, 2003 05:50 PM
