p0441
Old Feb 25, 2009 | 01:48 AM
lueSocal's Avatar
Question p0441
need help with obd2 p0441 96 z28 any suggestions?
Old Feb 25, 2009 | 04:18 AM
96m6lt1's Avatar
P0441
Evaporative Emission Control System Incorrect Purge Flow
Old Feb 25, 2009 | 11:15 AM
bobdec's Avatar
P0441 No Flow During Purge.. says the PCM picked the EVAP solenoid to suck fumes out of the charcoal canister , but the vacuum sensor switch in the canister line did not detect vacuum. Could be bad EVAP solenoid, bad vacuum switch but most common is something plugged with charcoal from the canister. Take a look at this picture from shoebox http://shbox.com/1/1996_evap.jpg . solenoid #7 picks, allows vacuum from intake manifold line #5 to pass thru solenoid, vacuum sensor switch #11 should see vacuum in line #1 that sucks fumes from the canister. Try blowing out the lines, make sure lines in/out of solenoid are clear..
Old Feb 26, 2009 | 07:22 PM
ACE1252's Avatar
You may have a hole in a hose somewhere.....make sure your hoses are not dry rotted. Mine were....I just bought all new ones(about 6 months ago).
sherwinZ28
11
Aug 15, 2015 05:38 PM
ineedarearend
Jun 19, 2010 12:29 PM
tyrsmkr
Aug 2, 2006 10:55 AM
smithtim
V6 Tech
Dec 9, 2005 11:43 AM
Ginobeatz2001
Jun 21, 2004 11:44 PM
