oxygen sensor the cause of stumble and pop?
Old Sep 25, 2012 | 02:07 PM
  #16
meangreenchevy's Avatar
Re: oxygen sensor the cause of stumble and pop?
Hey injuneer sry for the long response had a hard time finding a vacuum gauge. But I found one and I hooked it up to the intake manifold right next to where the brake booster line is I believe its for the egr but mines deleted and that port was capped off. At idle I'm reading between 16 and 17in/hg which I read is normal for a cc503. Any other ideas? Thanks so much for the help
Old Sep 26, 2012 | 06:24 PM
  #17
What are the chances it could be the maf and not throw a code?
Old Sep 28, 2012 | 06:35 PM
  #18
Anyone else in at a loss
Old Sep 29, 2012 | 06:18 AM
  #19
If all the data is unchanged from the frame you posted earlier, your problem is something that affects only one bank of the engine. While your extensions were not burnt, and "looked" OK, did you test them for continuity?
Old Oct 21, 2012 | 08:53 AM
  #20
I have not checked for that. no chance of the opti being bad right?
Nellsw88
May 27, 2015 10:27 PM
Lt1son
May 27, 2015 10:35 AM
ZZed
Jul 31, 2002 10:31 AM
Brian Wheeler
Jul 26, 2002 03:14 PM
busta9876
Jun 28, 2002 02:22 PM
