open loop
Old Aug 19, 2005 | 03:47 AM
bazzi's Avatar
open loop
i wanna change my car so it runs on open loop all the time. i have an lt1 edit. now what do i do to make it run on open loop all the time? i found somthing on the fuel tabels, Closed loop enable temp C. now i take it thats what i need to change. i just wanna make sure. thanks for your help
Old Aug 19, 2005 | 12:44 PM
Ricardo's Avatar
Re: open loop
That is exactly what you need to do.
Change the value of the closed loop enable temps to 150
You might need a wideband to really dial in your a/f ratio.
I run open loop all the time.
Old Aug 19, 2005 | 02:48 PM
bazzi's Avatar
Re: open loop
thanks man. do you find the mpg better on the open loop?
Old Aug 19, 2005 | 03:36 PM
Ricardo's Avatar
Re: open loop
I was able to completely clean up the idle by going open loop. When the Wideband showed 14.7 at idle in closed loop it was actually pig rich. I even tried the power enrichment trick without good results. Now my Wideband reads 17:1 at Idle.
I go 14.7 off Idle up to 3500 rpm and then 13:1 to 6700 rpm.
My MPG is much better in open loop, especially idling in heavy stop and go traffic.
I get around 12 MPG in the city (no stop & go) and around 17 MPG in the highway.
I did it mainly for driveability reasons. The 847 does not behave well in closed loop from 900 to 2300 rpm no matter what I tried.
It is very smooth and streetable now.
Old Aug 19, 2005 | 07:05 PM
bazzi's Avatar
Re: open loop
you mind if i look at your open loop file so i can get a starting point and then work my way from there
Old Aug 19, 2005 | 07:15 PM
turbo_Z's Avatar
Re: open loop
Bad idea... you must use a wideband o2 sensor or youll risk running too lean.
Also, Id shoot for a 16:1 afr cruising around if you wanna get better mileage.
93 RedBird
Nov 15, 2015 08:24 AM
NewsBot
Sep 30, 2015 04:20 PM
tommalcolm
Sep 11, 2015 03:39 PM
Toxintwins
Sep 11, 2015 11:13 AM
Daluchman1974
Sep 11, 2015 06:12 AM
