OBDII to I conversion- Can still diagnosis computer problems?
Old Sep 3, 2002 | 03:40 PM
ZDriver96's Avatar
Question OBDII to I conversion- Can still diagnosis computer problems?
I have a 96 z28. I took out the OBDII and Put in a OBDI tuned to my new engine mods. I have an ABS inop light that came on a few hundred miles ago. What do i do to diagnose a OBDI on a OBDII jack???
Old Sep 3, 2002 | 04:04 PM
slowpoke96z28's Avatar
Post
what type of scanner are you using. for most scanners that use vin #'s to know how to talk to the vehicle, when it asks for the tenth digit, try putting in a "s" or "r" instead of the "t" you would normally put. also, obdI diagnostics are not as detailed as obdII, and it isn't programmed to acknowledge the crank sensor(no more missfire check engine lights). any more questions, give me a call at 713.476.0684
Old Sep 3, 2002 | 06:23 PM
Ryan94ZA4's Avatar
Post
Well, your ABS codes aren't stored in the PCM so it really doesn't matter. If you want to check the engine, run it as a 95 as they also used the OBD2 connector with the OBD1 PCM. To check your ABS just put everything in as normal.
Ryan
1994 Z28 A4, Vortech, Borla with EBorla, TPIS 52 mm TB, Hooker shorties, Electromotive SDI, LS1 brakes, AAM 3.42 rear, more.
DirtyDaveW
Mar 15, 2015 07:01 PM
aj2494
Mar 12, 2015 10:17 PM
InfernalVortex
Jan 17, 2015 09:35 AM
cmdeshon
Jan 4, 2015 11:15 AM
AlaskaZ28
Jan 1, 2015 12:30 PM
