OBD1 High Stall Problem
Old Oct 18, 2005 | 06:48 PM
  #16
97Z-M6's Avatar
Re: OBD1 High Stall Problem
Originally Posted by Honda Hunter
From the research I did with the search and from everything Ive read everyone will tell you to get it done by pcm4less, Ion, or Fast chips. No one will openly say what exactly it is.
there is a garentee fix by ed wright, but remember if ed tunes your car, you cant scan it nor can you change programming. so your stuck
i did get the fix from one of the above names, but it wouldnt work on the 4400 stall, i had to change 2 other tables. in order to make it work. and it has not failed me since. and none of the persons mentioned above will garentee the fix but ed.
it took about 12 hours to figure out the fix for the 4400 stall, and it was acctually a better driver than the 2800 stall he had before, but the drive quality took alot of torqe covertor tuning.
Honda Hunter i have never heard any bad issues from this, and ive heard back from all but one person i helped.
Old Oct 18, 2005 | 06:57 PM
  #17
95WhiteTA's Avatar
Hey 97Z-M6, i've got bryan at pcmforless changing my tune for my 3200 stall, do you mind if i send you the file and let you look it over to see if you can further perfect it?
Old Oct 18, 2005 | 09:25 PM
  #18
97Z-M6's Avatar
yeah send it on. vincentbergeron@yahoo.com
load it first and see if it works. you might not need to send it. but ill look at it.
send it on
Old Oct 18, 2005 | 09:33 PM
  #19
95WhiteTA's Avatar
ok, i sent you the .bin file. I cant load the tune till i put my cam in cause the tune is for a Lt4 hotcam plus he threw the stall fix in there too. I could have got him to make another one with just the stall fix and no cam, but i didnt wanna make him go through all that.
Old Oct 19, 2005 | 01:48 AM
  #20
Honda Hunter's Avatar
Why cant you scan or change the programing? Is it really possible to stop someone from doing it??
Old Oct 19, 2005 | 01:54 AM
  #21
Deenasty's Avatar
he locks your file..I think you can still scan it, but not download the file or alter it..
Old Oct 19, 2005 | 02:52 AM
  #22
That's BS. No fix is worth that much. Now I want one of his files so I can unlock it and feel better.
Old Oct 19, 2005 | 03:08 AM
  #23
Mean Green Z28's Avatar
lol ... yeah, the professional/shop versions of most of the Edit sofware let you lock the tune ... interlectual rights yo! pretty gay but how would you feel if you spent countless hours fine tuning and fixing shyt and someone just coppied it and made mad dough with it? This is why I preffer to learn to tune my own car so I save a bunch of money and get the satisfaction of saying I did EVERYTHING!
Old Oct 19, 2005 | 03:14 AM
  #24
I guess I understand. Still pisses me off though. Hey Im from Gaithersburg as well.
Old Oct 19, 2005 | 01:26 PM
  #25
Deenasty's Avatar
well i spoke to Bryan Herter over at PCMFORLESS this morning, and he said he has a for sure gaurantee fix for this problem. He states "the VSS signal goes crazy because the tail shaft flexes, and sends the computer into limp mode." But he has the fix.
Old Oct 19, 2005 | 03:35 PM
  #26
95WhiteTA's Avatar
yeah bryan did the fix for me, i cant load the tune in yet and prove it worked. He told me the same thing, the tailshaft flex on a hard launch sends the computer into limp mode or something and it just shifts into 3rd and stays there to you get off the gas for a few seconds. He said some cars actually got stuck in 3rd gear till you cut the car off tho. My car took off, then would bogg and rev up but go pretty slow, cause it stuck in 3rd gear and wouldnt drop down till i let of the gas for like 3-5 seconds.
Old Oct 19, 2005 | 03:47 PM
  #27
95WhiteTA's Avatar
Old Oct 19, 2005 | 04:16 PM
  #28
Deenasty's Avatar
95whiteta, I sent you a pm, waiting for your reply..
Old Oct 19, 2005 | 09:15 PM
  #29
Dan K's Avatar
There is no trick to fixing it. On a hard launch, the vss loses signal and the computer goes into "limp" mode.
You need to make it so that the pcm doesn't use the vss for it's wot shift calculation.
...wow, this is the first time I've posted in here in a while.
Old Oct 23, 2005 | 09:19 AM
  #30
97Z-M6's Avatar
looks like it should work. but for a stall thats above 4000 i would change one more table but it should work for you
