OBD1 High Stall Problem
Re: OBD1 High Stall Problem
None yet. Want to do my homework before I buy one so I'll know what to change in tunercat w/ it.
Would be awsome if i could find some information on what table(s) relate to this.
sorry been gone this weekend.
im sorry i cant share what tables it is. theres one in the constants tables and some and the main tranny tables. if you get a stall i will help you if send the bin file to me. but i cant tell you what the table are because i told the person that told me i wounldnt tell his his secrets.
just a heads up, some people say that some times the fix dont work. but ive had 4400 stalls do great for a daily and preform great at the track. never not been able to fix one from tuning.
no i will not charge, but if you go and by a 3600 stall. theres no garuntee i can fix. but im willing to help and try.
ive fixed 9 or 10 of them for people on this board, and have never charged and never will. im here to give all the help and info i can give, and in exchange ill take all i can get from the other people on the board.
Originally Posted by shoebox
I seem to remember some information posted in this forum in the past...or maybe my memory is failing.
First off I would like to thank 97z-M6, for his response in willing to help fellow members, there are not too many out there like that. Second, I am thinking of doing a m6-A4 conversion, and will be running an Edge 3800 stall. I am trying to do a little research on this high stall problem, or sometimes referred to as "Stall wall". Is there a for sure fix for this? I am running OBD 1 as well. Also I didnt mean to hi-jack this thread. The question I have asked also pertains to the information trying to be seeked by the thread starter. Thank You!
i know some people change to obdII to fix the problem, how hard is it to change to OBDII? Do you have to change the whole wiring harness or could you hook up your PCM plugs to the OBDII pcm and just get a tune with the crank sensor and rear O2's removed? I think that's the only 2 main differences between OBDI and OBDII.
