obd ?
Old Feb 21, 2006 | 08:14 PM
slowpoke310's Avatar
obd ?
how do i know if my car is an obdI or obdII?
the car is a 1995 z28 vert.
my exh system comes with 2 cats
i dont see a crank pos sensor on my timing cover.
Old Feb 21, 2006 | 09:19 PM
moparman's Avatar
Re: obd ?
It's OBDI. OBDII started with the '96 models. The '95 models have an OBDII connector, so a lot of people think they are OBDII. Makes them hard to scan or pull codes without the proper cable.
Old Feb 22, 2006 | 07:24 AM
Re: obd ?
You will have an emissions label on the radiator cover. It should look just like the one from Shoebox's 95, and will show OBD-I, as Dave explained. The code in the upper left corner ("YHM") will be different, since your dual cats indicate you have a "CA emissions" A4:
Novo
Jun 14, 2016 02:58 AM
4586
Sep 6, 2015 03:10 PM
whitehooptie
Aug 10, 2015 07:02 AM
Aug 7, 2015 01:26 PM
Aug 7, 2015 08:52 AM
