OBD-1 won't scan
Old Oct 2, 2006 | 11:28 AM
  #16
infinitebird's Avatar
Re: OBD-1 won't scan
Originally Posted by milz
Like I said, I'm new to this, I'd much rather spend the money to buy a tool that I can possibly use later then fork over $$ to my local chevy dealer for a scan. Everyone is telling me what won't work, give me a recommedation of a scan tool that will work.
datamaster or freescan
Old Oct 2, 2006 | 12:03 PM
  #17
milz's Avatar
Thanks to all for the replies and a great website!
Old Oct 2, 2006 | 05:26 PM
  #18
You can find used AutoXray OBD-I scanners on eBay. You can go with the ScanMaster LT1. Actron and AutoXray make mid-level scanners that will read both OBD-I and OBD-II (sometimes requiring optional accessories). You can spend anything from less than $100 for the used AutoXray, to several hundred for the new Actron and AutoXray models.
Then there's software that you can download (often for free) and run on your laptop, with the correct cable ($50-100). Look at TTS DataMaster, FreeScan, EVILive V4. Do not look at Diacom. Cable is available from AKM Computing
Old Oct 4, 2006 | 04:52 PM
  #19
milz's Avatar
Finally got a good scan, code 29 which is the air pump. Fuse was blown, probably will pull the pump this weekend and see whats wrong with it. Thanks again to all for your help!
JJOHNROE
Parts Wanted
Oct 23, 2015 02:03 PM
Double aught
Oct 2, 2015 11:29 PM
jayblev95
Sep 26, 2015 09:44 PM
95craz28
11
Sep 12, 2015 07:47 AM
rideordie
Sep 7, 2015 08:22 AM
