which o2's to use?
Old Feb 10, 2010 | 06:28 AM
mightymouse383's Avatar
which o2's to use?
Need help with with my o2's on my obd2 to 1 conversion, do i use the downstream flat plug o2's or the upstream square plug o2's? The car now has pacesetter LT's and a cc306 and le2 heads.
Old Feb 10, 2010 | 09:37 AM
You use the same flat plug pre-cat sensors for both OBD-I and OBD-II.
The after-cat sensors have the square plug.
Front/Pre-Cat AFS75
http://www.rockauto.com/catalog/rafr...&a=FR321-AFS75
Rear/After-Cat AFS97 (now AFS123)
http://www.rockauto.com/catalog/rafr...&a=FR321-AFS97
Old Feb 10, 2010 | 09:39 AM
Originally Posted by lt1srule
Thats not Right..
Keep it up and there will be consequences.
Old Feb 10, 2010 | 09:40 AM
lt1srule's Avatar
Thats what i told him..
Old Feb 10, 2010 | 09:46 AM
lt1srule's Avatar
lol ..We just got his build togeather and it screams ..so not sure why he is asking..
Old Feb 10, 2010 | 09:47 AM
lt1srule's Avatar
Cause there is no codes..And it runs awsome..
Old Feb 10, 2010 | 09:49 AM
lt1srule's Avatar
Now i will have to get one of those sticky mouse Traps to catch that fast mouse..LOL
Old Feb 10, 2010 | 11:50 AM
But your answer was wrong.... somebody's going to do a "search" and find the incorrect info and believe it. That's not helping anyone.
Old Feb 10, 2010 | 04:18 PM
I thought it was the flat plug. I only have the two sensors connected, they are in the collectors of the LT's The reason i am asking is my o2 voltage at idle is very low it only changes from .300mv up to .500mv on the right bank and the left bank runs from .200mv to .300mv back and fourth. The BLM's at idle have a large split of like 15 to 20 from left to right, I have played with the idle fuel trims and still seem to have a large split. The left bank seems to run lean, the right bank has a steady BLM of about 127 to 126, the intergtator is at 128 which means no fuel correction right? Is the voltage reading low because the o2's are farther down from the engine in the headers causing them to indicate a lean voltage reading?
When I rev the engine the BLM's run right at 128 and the o2's go to .900mv, just want to try and tune for part throttle and idle, I still have to get a wideband for WOT tuning.
Old Feb 10, 2010 | 04:47 PM
lt1srule's Avatar
And the 02's have been extended buy cutting the wires and adding a foot of wire and putting wire clamps in between .could this be the problem..Cause the 02 wire is stainless steal and the added wire is not ?
Old Feb 10, 2010 | 04:54 PM
Generally a bad idea to cut the O2 sensor wires. Better to splice into the vehicle wiring harness, or buy a professional quality extension.
While the sensors are further from the engine, they are 4-wire heated sensors, and they should stay hot enough. Make sure you don't have any codes for the heater circuits. Is it possible you soaked them with WD40 or some sort of rust penetrant to remove them? That can screw them up. Did you use excessive anti-seize when you installed them, or perhaps contaminate them?
Are the sensors new? Are the headers coated? If they are new and cera-metallic coated, the O2 seem to die shortly thereafter.
Maybe its the airflow at idle, I need to open the idle screw more?
Old Feb 10, 2010 | 04:56 PM
You indicate you have access to reading the O2 sensor voltage and BLM's? How are you scanning it? If you have scanning software, post the scan data on an ftp site.
Old Feb 10, 2010 | 05:01 PM
Yes i know it was a bad idea to cut the sensor wires but i planned on replacing them anyways. needed to get the car running so i could get it home, could not keep it in the location it was at any longer. The headers are not new and the o2's did get a small amount of antiseize. The sensors also had to be hit with some PB blaster. so what u are saying is to just buy 2 new o2 sensors and get the exstentions right? Where do i find the exstensions? What brand o2's work best?
Old Feb 10, 2010 | 05:05 PM
I have tunercat and freescan, post it on ftp site? Is that like photobucket?
