Computer? Distributor?
Old May 29, 2008 | 11:27 AM
darlandz's Avatar
Alright so i have a 95 z28 auto and i have an accel optispark and right now i have to hold the key forward and it takes excessive cranks so i took it to the shop and they said it was code 36 check connection to distributor and if connection is good replace it but i have my fans kicking on right away too and a security light is on in the dash when i drive and the a/c is not working but not sure if it need s charged or if its the computer because i think it worked before this all randomly started one day. ses light is on. so should i replace the computer of the distributor? your opinion?
Old May 30, 2008 | 05:29 AM
Guest47904's Avatar
Guest
36 is high res pulse from the opti. Most likely wiring. The fans come on as soon as the PCM throws a DTC. Don't worry about the AC till you get the running problem solved. OBDI PCM's very very rarely go bad. Don't go throwing a PCM at it. Not yet any way.
Old May 30, 2008 | 08:46 AM
Closely check the opti harness for corrosion and good connection, first. The Accel optis don't have too good of a track record so far.
Old May 31, 2008 | 10:55 AM
Try getting is scanned again to see if you still have the same code, or if there are any new ones.
Old May 31, 2008 | 09:45 PM
darlandz's Avatar
good news my accel optispark II is still under warranty of one year so im taking it off and sending it back to summit and exchanging for a new ac delco optispark II and paying 10 more dollars. its a good start to better running, thanks for all the input i feel there is still hope yet
68camaroboltz
Oct 5, 2015 01:46 PM
autoxr166
Sep 25, 2015 04:21 PM
frankrizz
Sep 23, 2015 04:21 PM
fireside286
Sep 15, 2015 10:11 PM
